Gas Smell
Old Mar 12, 2007 | 01:12 PM
U240's Avatar
Gas Smell
I posted about this a few months ago and it had seemed to go away but it came back this morning the problem is if i let the car warm up ,when i get inside it smells like raw gas , and seems to do it when i stop at a light then when i pull off from the light i can smell the gas the heater is on when i can smell it . there is no smell under the hood and i`ve checked for leaks and cant find any,it seems to come from the vents any help is appreciated
Old Mar 12, 2007 | 03:10 PM
OBE1 95Z28's Avatar
Time to change your diet A common source of gas smell is from the charcoal canister and it's related vacuum lines. The canister is located in the wheel well behind the driver's side rear wheel (behind the plastic cover). The fact that you smell it when stopped at a light would allow the fumes to drift toward the front of the car and get sucked into the vent system. Sniff around the driver's side rear tire for gas fumes.
Old Mar 13, 2007 | 09:19 AM
smithtim's Avatar
getting any SES codes?
like said above usually the EVAP system canister does overfill after a while.. other thing that happend on mine was a little EVAP purge valve (or switch) under the hood that talks to the PCM... but it was reading a SES code
could be other things.. kind of hard to tell withount any SES codes. probbaly that canister is a good starting point and it's not that hard to pull
Old Mar 13, 2007 | 10:32 AM
U240's Avatar
no codes and the smell wasnt there today , would it have anything to do with how full the tank is
Old Mar 13, 2007 | 12:35 PM
smithtim's Avatar
I'd doubt it... but anythings possible
when my EVAP purge switch was bad it was kind of like that: one day could smell it then next day couldn't then a few days later could smell it again.. but I was getting an SES code on and off???
Old Mar 14, 2007 | 04:56 PM
will96's Avatar
Where did you guys get the new purge switch or whatever its called, mine is throwing codes and all that but i dont know where to get one, and do you know the price..thanks alot
Nayr
Mar 3, 2023 08:34 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Bails098
Aug 17, 2015 05:15 PM
