gas
Old Nov 3, 2012 | 12:33 PM
davidgeez28's Avatar
gas
I just bought a 93 camaro z28 is shell v power a good gas for it? i want to put the best.
Old Nov 3, 2012 | 03:33 PM
parkers Z28's Avatar
Re: gas
A little off topic here. In my opinion any 93 octane gas will do you fine
Old Nov 5, 2012 | 02:25 PM
Re: gas
Not exactly a "Show and Shine" topic. Let's move this.
Old Nov 6, 2012 | 09:48 PM
will.b.brown's Avatar
Re: gas
Shell made the most power in a gas comparison test I saw on tv a week ago or so. But all the gas brands they tested were ethanol blends. Someone may wana correct me if I'm wrong but if memory serves me well ethanol free gas will get you somwhere between 5-10% more power than ethanol blended fuels. It may actually be fuel mileage numbers that I'm remembering but even then, if its giving better mileage that means its making more power to. I believe we need to quit wasting corn on our fuel.
Old Nov 7, 2012 | 05:12 AM
Re: gas
Read your Owner's Manual. The minimum octane for avoiding lss of performance with spark timing retard is 91. You can use as low as 87 without damaging the engine, but you will lose power.
The above is based on sea level operation. The higher the altitude where you live, the lower the octane requirement. If your engine has heavy carbon buildup, you may still get some knock retard with 91 octane. You can use a scanner or data logger software to see if you are experiencing knock retard.
Go here for an Owner's Manual, courtesy of Shoebox:
http://shbox.com/pdf/manuals.html
Old Nov 18, 2012 | 04:11 PM
Re: gas
Good addition Injuneer. I think I figured he was using premium grade anyway since he wanted to be using the best of the best. Go find a gas station with PREMIUM straight gas though! It'll give the most mileage and power.
Old Nov 18, 2012 | 05:50 PM
Re: gas
Problem is, in the winter months, the EPA requires the use of oxygenates in gasoline, in areas where carbon monoxide emissions exceed Federal clean air standards. With the elimination of MTBE due to its hazardous nature, including contamination of ground water sources, alcohols are the predominate oxygenates. Depending where you live, you may not be able to find "straight gas".
Old Nov 18, 2012 | 07:21 PM
Re: gas
How about a fuel additive anyone have any recommendation ?? my car really doesn't see the road that much. " waxer "
Old Nov 19, 2012 | 07:37 AM
Re: gas
I've always read good stuff about chevron techron. If its fuel system cleaner that you're referring to. It's at most auto stores as far as I know.
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
