Fuel Line Retainer Broken
Old Mar 30, 2006 | 09:37 PM
b_lesy's Avatar
the retainer holding the fuel line up off the engine is broken and i saw in a bunch of other pictures on the net that other ppls are broken too. is this a common problem?
Old Mar 31, 2006 | 08:49 AM
Re: Fuel Line Retainer Broken
You mean the big plastic "ring" that holds the tubing bundle to the throttle linkage cover? Yes, they do break, and that can drop the lines on the manifold, causing a fire. I got a thick black nylon "wire tie", put the fat end inside, and through the hole in the throttle linkage cover, wrapped it around the fuel line bundle and back into the cover to connect up to the other end. Make sure the nylon tie does not interfere with the throttle linkage.
Old Mar 31, 2006 | 12:30 PM
b_lesy's Avatar
yeah thats exactly what i did. its clear of everything.
Old Mar 31, 2006 | 02:57 PM
OBE1 95Z28's Avatar
I'm using a tie wrap too but if you want the original part, it's 12048089 $2.21 from Shoebox's site.
Old Mar 31, 2006 | 05:37 PM
b_lesy's Avatar
oh really. what's the address for that site?
Old Mar 31, 2006 | 06:16 PM
OBE1 95Z28's Avatar
http://shbox.com/1/4th_gen_tech1.html
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
