Fuel guage
Old Jul 25, 2006 | 11:20 PM
19z28camaro02's Avatar
Exclamation Fuel guage
I just replaced my fuel pump and now my gas guage says 1/2 and its full, i 2x checked the connection at the sending unit, wtf?
Old Jul 26, 2006 | 02:09 AM
Craddock's Avatar
Re: Fuel guage
Maybe you bent the bar the floater is on? This is pretty common for the guage to mess up after a fuel pump change.
Old Jul 28, 2006 | 05:00 PM
cleangene's Avatar
Re: Fuel guage
just changed my pump out also, had to bend the pickup to match the old, but everything seems to be fine, found this web-page that will tell you how to check with ohm meter, hope it helps. did you drop the tank or go in from the top.
http://shbox.com/1/4th_gen_tech1.html
Old Jul 29, 2006 | 12:13 AM
Re: Fuel guage
did it from the top with a sawzall, then put plumbers goop around the edge so it wont rust even though i dont drive it in the winter, it worked out great cuz the float fell off when i put the sending unit back in
Zuvell
May 15, 2015 08:18 PM
markzzzz
May 8, 2015 09:21 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Devast8rSS
Jun 15, 2002 04:58 AM
