fuel consuption at 1/4 throttle
Old Sep 5, 2005 | 09:09 PM
number77's Avatar
I am wondering at what rate the ls1 or lt1 uses gas at 1/4 throttle.
Old Sep 6, 2005 | 07:13 AM
JakeRobb's Avatar
Super Moderator
Re: fuel consuption at 1/4 throttle
The LS1 uses slightly less than the LT1, AFAIK.
For cruising, it's much easier to quantify fuel usage based on RPM than it is based on throttle position, especially in cars with automatic transmissions. If I'm driving my Z28 at 70mph in 6th gear, I'm doing roughly 1550 rpm and getting roughly 29mpg. That works out to 2.41 gallons of fuel per hour. If we work it out even further, it works out to 0.0982 milliliters of fuel per revolution.
When you're accelerating, the car will obviously use more gas when you give it more throttle, but there is still a tie to engine RPM. If I floor it in 6th from 70mph, I'm not going to use nearly as much gas as if I did the same in 3rd.
I might have something wrong here, but I'm fairly sure about all that.
-Jake
Old Sep 6, 2005 | 08:58 AM
00cls1camaross's Avatar
wow that must be nice... i am ~ to 2100 rpms when i cruise around at 70.... damn A4
Old Sep 6, 2005 | 09:04 AM
JakeRobb's Avatar
Super Moderator
Hehe... 2100 puts me over 90! Long live the M6!
-Jake
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jul 4, 2005 05:00 PM
