Friggin driver window again :mad:
Old Sep 8, 2007 | 01:18 PM
PWR-TRIP's Avatar
I just replaced my driver side power window motor and now it's about to die again I want to know if i can get the power from my battery, so it speeds up the process? Would this be possible for my driver side window?
Old Sep 11, 2007 | 12:00 AM
Bayer-Z28's Avatar
Not sure if it'll work but check this out..
http://www.autotrix.net/
Old Sep 11, 2007 | 08:46 AM
PWR-TRIP's Avatar
Thats just for passenger side
Old Sep 11, 2007 | 10:40 AM
maro69camaro's Avatar
i do believe that will work on the driver side to just more likely to have this problem on the passenger side..
Old Sep 11, 2007 | 04:03 PM
BadgeZ28's Avatar
Have you tired the motor modification? There is a copper contact strip inside the housing that can be soldered at the contact points to eliminate the resistance feature. The resistance is built in so if someone gets their fingers caught in the window, the motor will only be able to exert to much force. Over time, these contacts weaken and you get less and less window speed. Maybe Shoebox has the mod at his site?
Old Sep 12, 2007 | 09:52 AM
scottso's Avatar
That kit works. I didn't buy it - but I did that mod quite a while ago with the materials I collected myself.
Keenan
Jan 19, 2023 12:24 PM
DSMKilla
May 26, 2015 10:10 PM
dale3in98
Feb 14, 2015 12:18 PM
Fatdog2
Jan 24, 2015 12:08 AM
kizz
Jul 6, 2002 11:03 AM
