Flow rates of cat converters?
Old Oct 3, 2005 | 04:16 PM
2QUIK6's Avatar
I've seen cat converter compared by cfm flow rates, but don't know what is sufficent for a good breathing 350 or 383 with twin cats/duals. I've seen 450cfm on some seems to be the high end.
But now I'm looking at some from Pypes, and they rate them as 5.9 liter and 6000 lbs or 5.0 liter at 4500 lbs???
I like the Pypes ones cause they are very small since I have a limited area to put them on duals, but not sure how they compare to others.
Old Oct 4, 2005 | 01:52 AM
Loony's Avatar
Re: Flow rates of cat converters?
You'll need about 2.2 cfm per horsepower(at the flywheel). If you use two cats just divide that number by two. This is just to get an idea...
Old Oct 4, 2005 | 09:12 AM
2QUIK6's Avatar
Thats good to know. So with around 500 flywheel hp I'd need at least 2 500+ cfm cats....that where the question comes in...
I see some cats with advertised cfm rating....while others list it as something like 4500 lbs capacity??? How do you compare that?
Here's a prime example..the Powermax is in cfm, the Pypes on the same page is in lbs.
http://www.rpmoutlet.com/powercat.htm
Old Oct 5, 2005 | 08:36 PM
2QUIK6's Avatar
Well I think I figured out the flows for all the ones I'm considering, who knows if they are at the same pressures/temps.
Pypes - 450 cfm for around $90
Dynatech Power Cats - 396cfm for around $150
Random Techs 7000 - 598cfm for about $175
So I think I'm going for the Random Techs if they will fit.
Old Oct 7, 2005 | 06:48 AM
Loony's Avatar
Have you looked into Carsound/Magnaflow cats? They're on EBay and were decent priced last time I checked...
Old Oct 7, 2005 | 08:55 AM
2QUIK6's Avatar
The MAgnaflows are 13" and 16" long, I won't have enough space to put them on I don't think with LT headers and have them before the support "bump" on the driver side without them hanging down a couple more inches. It looks like I'm going to have 11" or less to work with there.
Old Oct 26, 2005 | 09:33 PM
Ccass's Avatar
The lb rating is to help insure that the converter will pass inspection. The cfm rating is to give you an idea how much restriction the cats cause. In our dyno tests, the mini cats only cost about 2.5 hp on a 225 rwhp car. Also, look at the cfm ratings of cats. They outflow most chambered mufflers, so if flow is a big concern, start looking at the mufflers as well as the cats.
Old Oct 27, 2005 | 01:23 AM
TJ Chapman's Avatar
Where can I find Pypes cats? Or any comperable flow for the price cats?
Old Oct 27, 2005 | 05:17 AM
Loony's Avatar
Search for 'Pypes' on google
Old Oct 27, 2005 | 10:18 AM
2QUIK6's Avatar
http://www.pypesexhaust.com/mufflers.html
R@mpage
Apr 20, 2015 10:02 AM
thenewkid
Apr 12, 2015 07:42 PM
Fatdog2
Mar 31, 2015 06:50 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
