Fairly new A/C blows warm and smells odd sometimes
Old Jun 8, 2008 | 10:57 PM
Chevycobb's Avatar
Had the compressor replaced about a month and a half ago, it seemed to have been REAL cold then. was driving around today(high of around 95 outside) and noticed that sometimes the A/C would get warm. It would fluctuate quite a bit while cruising from cold to not so cold, and then back to cold when at idle. think there is an issue?
Also, I can smell what seems like a moldy type of smell when the car is first started, and then goes away a couple of minutes later. All of this just started today...its probably the hottest weather it has actually been driven in in a while, but the compressor is new along with the drier.
Old Jun 9, 2008 | 12:07 AM
Fatdog2's Avatar
Sounds like when mine was fixed.When they replaced the compressor,did they replace the outer thing(sorry for the layman terms),round thing that actually grabs the compressor to run it?It's the outer cap kinda thing that can't be re -used from the old system.If thats the case,they have to replace it ,otherwise the thing will keep slipping.You'll problably have to pay extra for this.Hope this helps.
Old Jun 9, 2008 | 03:54 PM
Chevycobb's Avatar
you talking about the clutch? that was replaced as well
Old Jun 9, 2008 | 07:12 PM
Chevycobb's Avatar
is it possible there is air in the system that seems to only show up when there is a load on it or something? just drove it briefly, and while I never noticed the smell, the temp would still fluctuate a lot while driving. At a stop and idling, it would get pretty cold.
Old Jun 9, 2008 | 10:38 PM
twozs's Avatar
its leaking and short cycling?
Old Jun 10, 2008 | 08:36 AM
Chevycobb's Avatar
haven't noticed any leaking...guess ill have to take it the shop whenever I get another day off
Old Jun 11, 2008 | 05:44 AM
Chevycobb's Avatar
chance I can get off of work early so maybe I can get to a shop. looking for other ideas of what can cause something like this.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
pimpen1024
Aug 19, 2015 08:36 PM
Noct
Jul 14, 2015 01:18 AM
