engine swap?
Old May 14, 2006 | 01:46 PM
project northstar's Avatar
Question engine swap?
don't know if this has been asked yet, but is it possible to swap out the 3.8L v6 in a 2001 firebird for a 4.6L DOHC Northstar v8? if so, what all is needed for the swap?
Old May 14, 2006 | 01:59 PM
jbird's Avatar
Re: engine swap?
possible, yes. practical, I think not. Have you seen under the hood of an LS1 or LT1 car? there is practically no room left for anything, and the northstar is a really wide engine with the dohc heads and all. You could probably make it fit with enough cutting and fabrication, but it's gonna take a heck of a lot of work.
The next question is why? If you're doing it to be unique, that's one thing in and of itself, but you could make a heck of a lot of power out of the LSX series of engines with a whole lot less hassle.
Old May 14, 2006 | 04:16 PM
Dave89IROC's Avatar
Re: engine swap?
It has been done
Old May 14, 2006 | 04:25 PM
2000GTP's Avatar
Re: engine swap?
I remember in an old issue of GMHTP, they crammed an LS6/T56 combo into a Cadillac Catera. I'm pretty sure you could do something like that vice versa.
Old May 14, 2006 | 05:11 PM
AlfredB18's Avatar
Re: engine swap?
I've seen pics of a Northstar in a 3rd Gen, but why would you want that maintenance NIGHTMARE in a 4th Gen???
The engine bolts up to a 60 degree bolt patterned tranny, so that's doable, but those engines are finicky...
If you thought tweaking an LT1 was bad, well, go for it if you want the challenge.
The Northstar spun off of the 3.4L DOHC v6, and we all should have an idea what a nag that is to keep up.
Old May 15, 2006 | 09:12 AM
Re: engine swap?
thanks to all of your replys and quick responses. as of right now i was only contemplating a motor swap. i thought of using the northstar motor b/c it was smaller and put out close enough numbers to a LS1 with less the displacement?! wasn't sure if it could be done to begin with though. so thanks again for the help...one more question though...is it possible/practicle to put a T56 up to the 3.8L in the 4th Gen F-Body? just another curiousity. thanks in advance~
Old May 15, 2006 | 12:56 PM
LT1Formulation's Avatar
Re: engine swap?
Look on www.LS1tech.com under the LS1 hybrid section... someone has a page where they did a Northstar swap in a 4th gen Camaro.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
