Electrical problems
Electrical problems
So for a while now my car has been hard to start, and sometimes loses power completely. Tonight after shutting my car off, I noticed the CD player would stay on until I pumped the brakes, then it would flicker. Also, should the RPM's surge by about 200 when you pump the brake? (While the car is on)
More background information: The car never idles right, dies when you put it into gear. It's way worse if you have accessories turned on (Heat)
I appreciate any advice on this matter. Thanks
I forgot to mention, it's on my new car, cammed 98 LS1 with stall, etc.
It could be a problem with the booster, I will check tommorow, but it happens even without the brakes.
Edit: ALSO, i have noticed that pushing the brakes while the car is running makes the lights flicker.
Thanks for the reply
eanhl2004
Apr 4, 2015 12:01 PM
