Electrical problem, please HELP!
Old Jun 6, 2004 | 02:27 AM
pewter99SS's Avatar
Unhappy Electrical problem, please HELP!
I have some kind of electrical problem that has me and my friends stumped. When I turn the key to the on position, the accesories all turn on and everything is ok seems like. But when I turn on the parking lights or headlights everything goes haywire and the guages max out, all interior lights dim. If I turn the key to start the car, nothing at all happens. It all started with my battery going out and wouldn't hold a charge. I changed that and no problems for a while. Then the car started doing this one day, just randomly. I have checked every fuse in the car, I have checked all the wiring I can think of in the dash and engine bay. I checked the ignition switch. I am out of ideas. Anyone ever had a similar problem.
Old Jun 6, 2004 | 08:48 AM
trackbird's Avatar
I can't tell you where it is located, but is sounds like you have lost a ground, either in the dash or to the headlights or dash lights. You may want to track down a wiring diagram and see where the grounds are located and start with that. You may find a manual at your local library (saves buying one).
Old Jun 6, 2004 | 12:41 PM
Dark Angel's Avatar
Either that, or check both battery terminals and make sure they are tight. This is the most common cause of that problem.
Old Jun 6, 2004 | 08:31 PM
1stls1's Avatar
Yes, sounds like still the batt connection . Please update.
Old Jun 6, 2004 | 10:08 PM
pewter99SS's Avatar
well turns out it was the battery connection. LOL! There have been 3 people in the last two days work on this thing and all of us have connected the battery at one time or another. I went out and tightened the positive and the negative as much as I could and sure enough that was the problem. After that it took me at least an hour to put the car back togather and I got it back on the road. Thanks for your help guys, I wish I had posted this sooner, lol!
Old Jun 6, 2004 | 10:10 PM
Gloveperson's Avatar
Don't 99's have bad wiring problems, or am I just remembering something that isn't true.
I would check for a bad battery connection. If that doesn't work, you may have a lost ground like trackbird said. Lets hope that.
FYI, I had a problem like that with my LT1, and it was a seriosly corroded battery wire and connetor.
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
