Electrical Problem?
Old Feb 12, 2005 | 10:27 PM
lindsZ28's Avatar
Electrical Problem?
Hello, everyone- this is my 1st post here, and sadly, its not a good one
Yesterday, I started my car, she turned over, then died. The clock reset, but everything else worked. I let her sit for a min, then started her up- fine. It happened again twice today. But, I have started my car up a few times today w/out any probs. Please help!!! Thanks everyone!!!
Lindsey
Old Feb 12, 2005 | 10:44 PM
Fuels94TA's Avatar
Re: Electrical Problem?
Check the connection on the battery post to see if they are loose. A loose connection will make that problem happen. Also a dead battery cell might be the problem.
Old Feb 12, 2005 | 11:48 PM
Help yourself and others by making a short signature that shows basic info about your car (at least year, model, transmission and any other pertinent mods).
Old Feb 13, 2005 | 12:03 PM
lindsZ28's Avatar
Thanks . . . did it
Old Feb 13, 2005 | 12:26 PM
86LT4Z's Avatar
I would suspect the battery if its the original Delco one.
Originally Posted by lindsZ28
Thanks . . . did it
Old Feb 13, 2005 | 02:32 PM
lindsZ28's Avatar
I checked the battery, connections, etc. - EVERYTHING is fine. So, now I'm completely stumped. The car is still cutting out when I try to start it, then will start right up on the second try.
Old Feb 13, 2005 | 04:43 PM
Fuels94TA's Avatar
Since you check the connection how about the post are they dirty with acid build up? Might have to take the battery out and have it tested for a bad cell. Also I just wanted to make sure your saying that the radio/clock would reset it self every so often.
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
