electric or manual cutout?
Old Feb 16, 2006 | 11:34 AM
MENEGRANDE's Avatar
so, i want to install a cutout, is it worth it speding the x-tra dollars for a electric one? we get a lot of rain here, wouldn;t it get damaged? thanks.
Old Feb 16, 2006 | 12:00 PM
firebirdStud's Avatar
Re: electric or manual cutout?
the e cutout is aluminum in most cases, so I don't think rain would hurt it. I have an e cutout that will be installed within a month. I wanted it for the simple "push of a button." I want to be able to scare the sh*t out of someone with the flip of a switch, or turn it to closed when I see the local county brownies. Pig pigs don't like noise. This allows you to drive open or closed, all without leaving the cockpit!
Not sure on reliablity of the e cutout, as I have not put it on yet. I am sure they are fine though, as long as you tuck them up there good so speed bumps don't eat them! :-)
Old Feb 16, 2006 | 12:03 PM
MENEGRANDE's Avatar
i'm having speed, inc installing a ecutout for $349.00 total. sometime next week
Old Feb 16, 2006 | 12:05 PM
nb 96 z's Avatar
I have an electric one and have had no problems with it so far and its been in the rain. I think its more convenient than crawling under your car every time to open or close it.
Old Feb 16, 2006 | 12:07 PM
nb 96 z's Avatar
Have someone weld it in and intall the electric motor part your self. You'll save $300 and it's pretty easy. Do a search and look for writeups on installing an e-cut out.
Old Feb 16, 2006 | 02:44 PM
Stoopalini's Avatar
No problem in the rain. I've had mine for a few years now, and it works great!
Thomas.
Old Feb 16, 2006 | 02:55 PM
LOW TRAC's Avatar
I went with the cheep wingnut cutout from Summit, had it welded in place of the cat and after the first winter all the wingnut wings broke off when trying to remove the cap. If you drive it in the snow you'll run into corrosion problems no matter what its made off but just in rain it should be fine.
Old Feb 16, 2006 | 03:53 PM
pHEnomIC's Avatar
I have a manual one on my z/28. Love it. Ive closed it probably 3 times, its open all the rest of the time.
Old Feb 16, 2006 | 07:16 PM
00cls1camaross's Avatar
yeah i have a flowtech cutout an di only cap it when the charlie batch is coming with me in the car and we are going to a classy place; also when i go on long trips since the drone occures from about 2k-2.5k and that is cruising rpms
Old Feb 17, 2006 | 09:02 PM
flatlander757's Avatar
It's not necessary but is definitely cool and you'll still come out cheaper than a full catback
I've found it's nice to have if you're crusing and the car starts making a weird noise(like freaking a quick clicking noise from the front end) you can close it to listen closer.
I think I have a messed up piston or pin or something
But anyways, go for the manual cutout first, and if you ever want the switch then just go for it. It's not like you can't add it later.
Also mine works fine in the rain, though I don't usually fiddle with it much. As long as you don't hold the switch longer than it needs to be(stressing the motors at full open or full closed) it should be fine.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
