Easiest way to drain fuel
Pick yourself up a cheap electric fuel pump from Advance or Autozone. Hook it to one of your fuel lines and wire it live to your battery and stick a peice of fuel line into a gas can. Easy as can be.
I dont think you can siphon these cars. If I am not mistaken there is a safety screen or something in the fill tube, but if not you can use the previous mentioned method down the fill tube.
Usually, on LT1's, there is a small red wire with a black connector near the passenger side PCM location. Patch (with jumper) in 12+vdc from the batt (with Ign off) and this will drive the fuel pump. Usually you can disconnect at the fuel rail and run to a 5 gal can. Disconnebt alt 12vdc source when pump starts to scavenge air and fuel delivery runs out. B,
Sandersen511
Jan 13, 2015 03:49 PM
