DTC Codes on a Switch?
Old Apr 17, 2009 | 02:01 AM
silentsprintero's Avatar
I remember reading somewhere about hooking up a switch to your DLC. For my '93 would it be a matter of tapping a wire from Port B (Diagnostic) to the power side of a switch, and grounding the switch? Once it is flipped the DTC's should flash with key to "ON" engine "OFF" right?
I ordered a cubby hole plate from 6LITEREATERDESIGNS and I'm working on a few switches and two gauges to put in. Pics will be up in a couple weeks after I get all the parts in and get them installed
Thanks in advance!
Old Apr 18, 2009 | 10:14 AM
What you would be doing is installing a "switched" short/jumper between ALDL connector pins "A" and "B".
http://shbox.com/1/dlc2.jpg
Seems like it would be a lot easier just to use a paperclip when you want to flash the codes.
Old Apr 18, 2009 | 10:47 AM
Yes, it is easy doing the paper clip but I hate trying to fumble with it trying to keep it in the DLC. Sometimes I have to wiggle it around and keep it in the right spot to get the fans to come on and show the SES light.
Plus I'm one of those weirdos that likes switches
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
maybe2fast
Mar 16, 2015 11:59 AM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
Aug 5, 2002 01:39 PM
