Door lock replacement
Old 03-29-2006, 03:57 PM
Jake77444's Avatar
Hello everyone,
I got a problem, it seems someone tried to break into my drivers side car door. I have power door locks but lost the remote, so I must use a key and when i slide the key into the drivers side door it goes in but does not turn anymore. I cannot feel any of the threads catching like i do on the passenger side door when I slide the key in, it seems like they just put a screw driver in the door lock and stripped everything away so my key does not work. I am wondering what would be the best way to repair/replace this. Should I buy two new locks so they use the same key? Im also unsure on the exact part I need when I look it up on gmpartsdirect so if anyone could tell me what parts I need it'd be extremely helpful.
Thanks,
Jake
Jake77444 is offline
Old 03-29-2006, 09:06 PM
JaysGone's Avatar
Re: Door lock replacement
As a locksmith thats where Id take it. Now that being said. Finding 1 who works on car cylinders is another story. Cant give you much more advice then that.
JaysGone is offline
Old 03-31-2006, 02:25 AM
Jake77444's Avatar
Im leaning towards the replacing of the locks completely, i know what you locksmiths charge!!!
Old 03-31-2006, 06:41 AM
JaysGone's Avatar
Good luck replacing 2 doors the rear deck and glovebox for what we would charge for 1 "coded" door cylinder installed. At my shop it would be around $100. More then fair for a cylinder and an hours labor.
JaysGone is offline
Old 03-31-2006, 11:43 AM
Jake77444's Avatar
Well maybe ill get some estimates then because that doesnt sound to bad, honestly before you told me I didnt even realize locksmiths could do that
Old 03-31-2006, 12:22 PM
Z28SORR's Avatar
You don't have to buy all new locks. You just get one and file the tumblers to your key. If you can't do this, it will take a Smith about 5 min.
Z28SORR is offline
Old 03-31-2006, 01:25 PM
Jake77444's Avatar
Thanks for the help guys, this is much simpler then i made it out to be i can get the cylinder from brown and brown for $21 bucks and have it coded for $15
Thanks again
dale3in98
02-14-2015 12:18 PM
sscott
01-17-2015 04:30 PM
cmdeshon
Parts Wanted
12-16-2014 07:58 AM
Roshambo
09-04-2002 11:25 AM
Mad_Ice
07-29-2002 09:44 PM
Quick Reply: Door lock replacement
