Door alignment
Door alignment
My driver door it slightly sagging; When I close it, the bottom touches the body of the car; I guess I need to loosen it and straighten it but I have the feeling that is going to turn to hell very quick.
Has anyone realigned the door before and could tell me the right process?
either the pin is worn or the bracket is bent. is it rubbing at the front of the door at all? if so the bracket is probably bent. i have read that you cannot just replace the pins in our doors.
the bottom of the door it hitting the body of the car when I close; it is very slight, but I can see it; it hits at the furthest point from the hinge.
I'll check with a body shop to see what they say
I have the same issue on my car but it isnt really just the hinges... The actual fiberglass of the door where the hinges are mounted is starting to come apart... I am going to have to replace the whole door... so just make sure to check if the fiberglass isnt cracking there
It is a 2000 but I had bought it off a guy who repaired the whole car due to a wreck in the rear. It could be some hidden damage that has finally come out do to more wear and tear on the car or I have been to rough on the door.
Aaront810
Aug 29, 2020 09:34 PM
RUENUF
Mar 13, 2016 03:37 PM
z28cam1993
Sep 9, 2015 04:08 AM
