Does this effect your Dyno results?
Old Mar 6, 2006 | 05:37 AM
lil305gta's Avatar
Sawwping form a 3.23 to a 3.73 rear end? I can't recall if it was the gear swap of stall converter that effects you with a lower dyno output. If so by how many does it lower your output?
Old Mar 6, 2006 | 07:03 AM
mook99TA's Avatar
Re: Does this effect your Dyno results?
switching to 3.73's will affect your dyno numbers and give you a lower rating but by how much I am not really sure.
Old Mar 6, 2006 | 07:26 AM
Greed4Speed's Avatar
The converter will, especially if it isn't locked. It allows more slippage.
Old Mar 6, 2006 | 07:55 AM
SladeX's Avatar
Changing gears doesn't usually affect hp/torque numbers, I tested this on my auto before running a run in 2nd gear and one in default 4th gear, hp and torque came out the same.
Putting a stall in will change the numbers though, it will be lower.
Old Mar 6, 2006 | 02:29 PM
GreenDemon's Avatar
Someone posted about this quite awhile ago, supposedly he lost somewhere between 5 & 10 hp going from 3.42 to 4.10, I believe. Not really surprising, all that extra spinning will drop your hp down a bit same as bigger rims & tires, but it's how fast the car is that counts, hot the numbers.
Old Mar 6, 2006 | 03:59 PM
mook99TA's Avatar
exactly take it to the track for the best comparison
fift5
11
Oct 1, 2015 10:31 AM
HAWG
Sep 25, 2015 11:41 AM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
