Do Performance Induction systems increase noise?
Old Jan 20, 2006 | 03:56 PM
V8 Slayer's Avatar
Things like Cold Air Intakes, Bigger Throttle Bodies and Manifolds/Runners. Do they increase noise? or is that just a myth?
Old Jan 20, 2006 | 03:59 PM
2000GTP's Avatar
Re: Do Performance Induction systems increase noise?
A cold air intake will definitely increase engine bay noise. Take a look at a factory air box on a car and you will see all the baffles and restrictions that are in place to cut down on noise. Then take a look at an aftermarket CAI kit which is just a open filter and a tube and you'll see the difference.
Old Jan 20, 2006 | 04:12 PM
myslowcamaro's Avatar
slightly, but not to the degree of an exhaust.
Old Jan 20, 2006 | 06:46 PM
magnumv8's Avatar
a cai will create more of a sucking noise under acceleration, but it is not bad. I like the sound of the engine sucking the air in.
Old Jan 20, 2006 | 11:06 PM
Critter's Avatar
you will hear a sucking from a cai... in my car it also made the exhaust a hair louder.
Old Jan 22, 2006 | 11:49 PM
Compstall's Avatar
LT1 F-bodies aren't too bad because the filter sits way down in the lower driver's side in the fender. My Durango was a whole different story, as the filter sits up top and on the side. I can hear that CAI plain as day right through the firewall. Sounds cool too..
Old Jan 24, 2006 | 10:21 AM
wrd1972's Avatar
You will hear a whoosh like sucking sound when you mash the fun pedal only.
My Arizon speed and marine makes an even louder sound then the Moroso CAI I had.
Im not sure what this indicates.
I could hear additional noise when I removed the OEM rubber elbow with the elephabt trunk silencer and replace it with a trick-flow metal elbow.
Generally when more air volume is moved through an opening it will produce this kind of noise.
Old Jan 24, 2006 | 12:55 PM
Bert02SS
Guest
Posts: n/a
No myth. When I put an FIPK on my '96, there was a noticeable and welcome increase of induction sound. (Not noise!)
Old Jan 24, 2006 | 01:39 PM
ReNxWar's Avatar
I can clearly hear the CAI when accelerating (If I'm looking for it), and I can hear it from outside the car when its idling. I personally think its a cool sound, and kind of covers up the LT1 tick.
Old Jan 24, 2006 | 02:19 PM
ImportKILLER's Avatar
I have the SLP CAI and it is very loud during cold starts. Loud gurgling noise that goes away as the car warms up. Before I installed my exhaust, I could hear a "spooling" type noise from the engine under heavy acceleration that I suspect was from the CAI (others reported similar noises).
But its been years since I've heard from my CAI...loud exhaust and loud stereo.
Old Jan 24, 2006 | 05:17 PM
wdtiger's Avatar
I love it. I had a '72 Chevy truck with a 350 in it. I pulled the original intake mani and Q-Jet carb and threw on an Edelbrock intake mani w/ a Holley 650cfm carb w/ vacuum secondaries. What a difference... even over the headers and dual flowmaster exhaust, you could hear the "whoosh" of sound when secondaries opened up.
I also have an AEM Short Ram intake on my Integra. Big difference in sound over stock on that, too. Not nearly as cool as my truck was, though. lol.
Old Jan 25, 2006 | 12:17 AM
Skull Leader's Avatar
Arrow Re: Do Performance Induction systems increase noise?
I can hear mine from about 15 feet away in front, moreso near the windsheild because of my cowl induction hood.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
