Do Performance Induction systems increase noise?
Re: Do Performance Induction systems increase noise?
A cold air intake will definitely increase engine bay noise. Take a look at a factory air box on a car and you will see all the baffles and restrictions that are in place to cut down on noise. Then take a look at an aftermarket CAI kit which is just a open filter and a tube and you'll see the difference.
LT1 F-bodies aren't too bad because the filter sits way down in the lower driver's side in the fender. My Durango was a whole different story, as the filter sits up top and on the side. I can hear that CAI plain as day right through the firewall. Sounds cool too..
You will hear a whoosh like sucking sound when you mash the fun pedal only.
My Arizon speed and marine makes an even louder sound then the Moroso CAI I had.
Im not sure what this indicates.
I could hear additional noise when I removed the OEM rubber elbow with the elephabt trunk silencer and replace it with a trick-flow metal elbow.
Generally when more air volume is moved through an opening it will produce this kind of noise.
I can clearly hear the CAI when accelerating (If I'm looking for it), and I can hear it from outside the car when its idling. I personally think its a cool sound, and kind of covers up the LT1 tick.
I have the SLP CAI and it is very loud during cold starts. Loud gurgling noise that goes away as the car warms up. Before I installed my exhaust, I could hear a "spooling" type noise from the engine under heavy acceleration that I suspect was from the CAI (others reported similar noises).
But its been years since I've heard from my CAI...loud exhaust and loud stereo.
I love it. I had a '72 Chevy truck with a 350 in it. I pulled the original intake mani and Q-Jet carb and threw on an Edelbrock intake mani w/ a Holley 650cfm carb w/ vacuum secondaries. What a difference... even over the headers and dual flowmaster exhaust, you could hear the "whoosh" of sound when secondaries opened up.
I also have an AEM Short Ram intake on my Integra. Big difference in sound over stock on that, too. Not nearly as cool as my truck was, though. lol.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
