Do High flow cats last as long as stock?
Old Jun 3, 2005 | 09:03 AM
Bobsep84's Avatar
I was looking into getting a random technology high flow cat but i was wondering if aftermarket cats last as long as factory ones do?
Old Jun 3, 2005 | 08:31 PM
littlbasterd's Avatar
Re: Do High flow cats last as long as stock?
random tech is a good company..so they shouldn't be to bad, life wise. check to see how long of a warrenty they have..bud most hi-flow cats do burn out sooner than factory ones
Old Jun 5, 2005 | 10:44 PM
OBE1 95Z28's Avatar
Cat failure is also related to how your engine is running. Running rich causes premature cat failure.
Old Jun 8, 2005 | 07:45 PM
2cub49's Avatar
I have Random cats and they're warrantied for 5 years for the casing but only 2 years for emissions.
They're expensive and if I had to replace them I'd get a set of these:
http://216.178.81.107/iwwida.pvx?;it...0%201?comp=ppe
Old Jun 8, 2005 | 08:00 PM
00ls1's Avatar
id go with the random tech cats.. there a good company id trust them but to be sure id call the company and ask what the life of them is
Old Jun 14, 2005 | 07:22 PM
Ccass's Avatar
I believe by federal regulation, aftermarket converters have to be warranteed for 5 years or 50,000 miles. If not, that's what the Pypes warranty is anyway.
Old Jun 14, 2005 | 10:10 PM
boyd's Avatar
I put a Random Tech cat and SLP y-pipe on my 94Z in Jan 2000 and it started to rattle ( broken Brick) in Dec of 03. My car does run a little rich and it just so happened to be about the time I had been planning on replacing my plugs and wires, so...
New plugs and wires with a "gutted" cat.
Now my rear bumper cover really gets black, the car is white.
Old Jun 16, 2005 | 12:04 PM
White Knight 95's Avatar
I also had a Random Tech cat that started to rattle after a couple years. When I pulled it off, it was not actually the honeycomb that had broken apart, but rather the padding that holds the honeycomb in place. So, basically I had the entire honeycomb substrate rattling around in there.
I called Random Tech and they said this might happen if i had been running rich, and excess fuel built up on the padding. Then they said that it could ignite the padding and cause it to burn away. Granted, this was partially my fault due to the rich running car, but it also seems a little crazy that the entire cat was ruined b/c of the padding.
Since I had just bought the cat afew years ago, they offered me a 'discount' on the new one ($170).
Personally, that still seems a little expensive for a cat replacement within a couple years.
HectorM52
Jun 23, 2016 08:42 PM
jeff94z28
Sep 11, 2002 02:01 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 04:41 PM
blue89iroc
Jul 18, 2002 03:35 PM
