Do cam shafts cause faulse misfires?
Old Apr 3, 2006 | 09:34 AM
97SLPcamaroSS's Avatar
OK i have the whole LT4 cam and springs. RR. and on the Scan Tool the car is showing Misfire's some are rolling and some are random misfire's. So the question is do cam shafts cause a faulse misfire or is the car actually misfireing under a load misfires seem to stop.
Old Apr 3, 2006 | 09:59 AM
Camaro97USAF's Avatar
Re: Do cam shafts cause faulse misfires?
The Lope is what causes it from what I'm told. The pcm sees lope as an erratic crank rotation, in other words, a misfire. You can adjust the random misfire parameters in the PCM to only come on a certain RPM or so to prevent the light from coming on.
Old Apr 3, 2006 | 11:38 AM
lt11997's Avatar
I have the hotcam on a stock tune right know and the Tech II isn't showing any misfires on my car.
Old Apr 3, 2006 | 11:59 AM
hum well the opti just went out too so it might be a little bit of both playing with the TECH2. Keep the info comming thanks
AdsoYo
May 2, 2018 03:21 AM
Victor Lamb
Aug 26, 2017 02:52 PM
Klypto
Mar 23, 2016 09:05 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
KYWes
Apr 15, 2015 07:28 PM
