DIY AC Recharge
Old May 15, 2006 | 10:29 AM
1quickTA's Avatar
DIY AC Recharge
I had my AC system completely bled out during my cam install and the shops are wanting like $115 to recharge it. How much would it cost me to just do it myself (pressure gauge and R134), and how much R134 would I need to completely fill the system since there is zero left? Thanks.
Old May 15, 2006 | 12:44 PM
ACE1252's Avatar
Re: DIY AC Recharge
I was going to do this to my brother's car on which I am replacing the engine.
I'm not sure exactly what the answer is to your question, but I think the recharge kit will tell you how many cans max. to put into the system.
Consider this though....I've been told that it's not as simple as recharging the system. It seems as though since the system has been exposed to moisture that it will need to be evacuated of moisture, recharged, and then checked for leaks.
I don't know if it will be ok, but I thought I'd just tell ya what I had found out.
Old May 15, 2006 | 12:46 PM
Ray86IROC's Avatar
Re: DIY AC Recharge
I did it for somewhere around $30-ish, about $7-$8 per can of r134a if memory serves, and a few bucks for a can of oil for the system. If I recall it took 3 cans of r134a, I'm sure someone will pipe in with specifics.
But the shop will pull a vacuum on the system, remove all moisture, etc to do it right. I didn't do that and mine works great but still... Mine was only discharged for like a week when my compressor went out.
Old May 15, 2006 | 12:48 PM
J Rod's Avatar
Re: DIY AC Recharge
I used one of those DIY kits from autozone after I swapped cams in my LS1. Worked like a charm. I can't remember how much I used though, that was like 3 yrs ago. lol
Old May 15, 2006 | 01:09 PM
Mtrhds94Z's Avatar
Re: DIY AC Recharge
2 pounds of R134..
malikot02SS
Aug 15, 2015 01:11 PM
95Zdroptop
Aug 17, 2003 02:05 PM
Naegash
Aug 14, 2003 04:09 PM
luis nunez
Aug 2, 2003 01:24 AM
Markolc
Feb 16, 2003 06:03 PM
