Disabling interior dome lights?
Old May 24, 2005 | 07:59 PM
8BaLL's Avatar
I HATE how the lights come on when you open the door. I don't see the pressure switch on my 2001.. Anyone got some info on this? All i had to do on my 95 was cut the wire on the door.
Old May 25, 2005 | 01:29 AM
Lower's Avatar
Re: Disabling interior dome lights?
Why not just pull the bulbs?
Old May 25, 2005 | 06:32 AM
teke184's Avatar
then if you need the lights...they aren't working.
sorry can't help you much. maybe look inside the kick panel for a switch
Old May 25, 2005 | 06:35 AM
On mine, the door switch is on the body, below the lower door hinge. I've seen people put a piece of metal with a screw next to the switch, so you can depress the switch and pivot the piece of metal over it to keep the switch from popping out when you open the door. That way, you have the option of moving the metal strap so the lights will work when you want them to.
Old May 25, 2005 | 07:42 AM
8BaLL's Avatar
Yes that's where it is on my 1995, but it's not there on my 2001.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Heathen1
Jan 2, 2016 04:27 PM
silvermansteve
Mar 4, 2015 05:02 PM
Collector Car
Jan 5, 2015 10:58 AM
