disabeling airbags on 94z28
Old Aug 2, 2012 | 10:49 PM
CR0067's Avatar
What all is involved in disabeling the airbags and all associated sensors and equipment. Can I just disconnect the sensors in the front and leave the airbags in place for now. This is going to be a track toy.
Old Aug 3, 2012 | 08:22 AM
Re: disabeling airbags on 94z28
I would imagine unfusing them would render them inoperable. Then after a little bit (to allow any residual power to leave the system), I would unplug each air bag.
Old Sep 2, 2012 | 12:12 PM
1994BmtZ28's Avatar
Shoebox is right...remove the "air bag" fuse then unplug the bags. One plug is at the base of the steering wheel and the other behind the glove box. Both are "Connector position assurance" (CPA) and yellow two-way SIR harness connectors. The one behind the glove box is near a yellow 24-way DERM (Diagnostic/Energy Reserve Module) connector on the instrument panel wiring assembly. With the fuse removed and ignition switch in "RUN", air bag indicator lamp on instrument panel cluster assembly will light. This is normal operation and does not indicate an SIR (Suplemental Inflatable Restraint) fault. Quoting the 1994 GM shop manual.
Old Sep 8, 2012 | 03:55 AM
CR0067's Avatar
Ok, thanks!
240ssLs3
Jul 13, 2015 05:06 PM
CamaroJim
Mar 22, 2003 06:29 PM
Jan 27, 2003 10:23 PM
Dave89IROC
Dec 29, 2002 11:40 AM
headingeast
Mountain
Jun 17, 2002 09:45 PM
