Did some minor maintenance, now car won't start! Please help!
Old Sep 29, 2012 | 08:20 PM
Shibs's Avatar
Hey guys, so here are the details...
I took my car to the auto skills center to change my oil. Did that first, no biggie.
note; I disconnected my batteries before I changed the oil.
I then had to replace the plastic piece and wires that the turn signal lever connects to because my right blinker has been very sensitive. I started by removing a couple panels that go around the turning signal switch. No biggie, they just snapped out. I then removed the steering wheel column adjuster. After that, I took a phillips and removed my hazard signaler. Then the airbag, I disconnected the two wires behind that. I then disconnected my steering wheel, planning on the extra working room.
I lost track of time and the damn place announced they were closing in an hour. So I threw everything on really quickly and yes i DID connect the only two wires attached to the air bag that I disconnected earlier. I put the hazard switch back in, and plugged my batteries in. Then my hazard lights came on and wouldn't go off. ****. No biggie I thought, I'll just fix it at home. (I live right across the street.) So I went to turn my car over, and it made a weird electrical kind of click noise, and the car wouldn't turn over. It didn't even try to. So now I'm thinking WTF?!
I have no idea what could have caused this. I reconnected the only two wires I disconnected earlier. What's the problem here? So now my car is stuck at the auto skills center overnight while I try to plan on what I'm going to do in the morning.
Can you guys please help me out with any advice. I really need my car for transportation this week!
Again, thanks for any responses!
Old Sep 29, 2012 | 08:45 PM
mrmint69's Avatar
Re: Did some minor maintenance, now car won't start! Please help!
I would make sure everything is hooked back up correctly including the battery. Maybe a fuse was blown or something along that line. Sounds like when your battery is nearly dead and the only noise is from the solenoid.
Old Sep 29, 2012 | 09:21 PM
Wilson's Avatar
Try leaving your door open so the interior light is on and then crank the engine over. Watch the interior lights, if they go really dim/dark u have a dead battery. Hence the clicking sound. If you have a multimeter then check the battery voltage.
Old Sep 29, 2012 | 10:49 PM
Not enough "details" - need info about your car - year, model, engine, trans and any major mods. Impossible to provide accurate help without that info. Add a "Signature".
Old Sep 30, 2012 | 02:28 AM
Shibs's Avatar
Alright thanks for the tips guys. I'll try this tomorrow morning. And sorry I'll add a sig now.
Queens94z28
Dec 20, 2014 09:11 PM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
