defroster?
Old May 31, 2006 | 03:24 PM
whtdvl's Avatar
defroster?
I think my rear window defroster has gone bad...if that is possible. At one point in time it would practically burn the moisture off of the window, now this morning in the it was barely doing anything..Any ideas? I've already checked to make sure the wiring was connected..TIA
Old May 31, 2006 | 04:06 PM
Lunch Box's Avatar
Re: defroster?
If I'm not mistaken there's a timer built into the defrost switch that can over tiem stop working right (the on/off cycles get out of whack) and I'm sure that over time the defrost elements themselves on the window can stop working right, either too much resistance or a break in the circuit somewhere
Old May 31, 2006 | 06:59 PM
96ZCamaro's Avatar
Re: defroster?
Yea, my defroster will turn off by itself after having it on not too long at all. And I always have to keep turning it back on, gets really anoying. How in the world could I go about fixing it?
Old May 31, 2006 | 07:06 PM
whtdvl's Avatar
Re: defroster?
it comes on...it just takes forever to defrost the window..it seems to run the same amount of time it always has...it is just becoming less effective...i hope solving the problem doesn't mean replacing the glass
Old May 31, 2006 | 07:18 PM
Re: defroster?
Try replacing the 30 amp breaker with a 30 amp fuse. It has worked for a lot of folks.
Old May 31, 2006 | 07:23 PM
Re: defroster?
Grid testing info.
Old May 31, 2006 | 08:08 PM
whtdvl's Avatar
Re: defroster?
i'll take a look at it to make sure that everything is in tact....what would the breaker to fuse conversion require? TIA
Old May 31, 2006 | 10:36 PM
Re: defroster?
A fuse...
That post was meant for 96ZCamaro's problem, not yours.
You remove the breaker and install the fuse in it's place.
Old Jun 1, 2006 | 07:33 AM
whtdvl's Avatar
Re: defroster?
gotcha...i guess i just gotta get out the chamois every morning
Old Nov 27, 2007 | 08:33 AM
Turbozombie's Avatar
Will changing to a 30amp fuse affect any wiring or any other electrical items?
Old Nov 27, 2007 | 09:57 AM
No.
Old Dec 10, 2007 | 08:38 AM
I replaced the breaker with a 30amp fuse. The fuse blew within 2-3 mins. Is this an issue with the rear window defroster lines?
Old Dec 10, 2007 | 03:34 PM
Could be. Something is causing too much current draw.
whitehooptie
Jul 12, 2015 06:10 PM
slopokrodrigez
Jul 25, 2003 08:27 AM
johnpsz
May 1, 2003 08:10 AM
Capn Pete
Jan 8, 2003 09:41 AM
Aneurysm
Oct 6, 2002 05:17 PM
