Dash swap obd1 to obd11???
Old Mar 2, 2009 | 01:55 PM
meangreenchevy's Avatar
okay guys i have a 94 camaro v6 obd1... i am putting in a 97 camaro lt1 obd11... i want to put in the dash out of the 97 (have dash already)... okay i have 2 questions first one is will the digital odometer work in my car being that now its mechanical... and i want the car to be able to scan for obd11 but the scan plugs are different can i make this work? plz any info will help noone can seem to answer this...
Old Mar 2, 2009 | 06:43 PM
94arcticwhiteM6's Avatar
just a guess i would say you would need a 97 bcm, ecm and harness.
Old Mar 3, 2009 | 05:06 AM
There are differences in the wiring harnesses, particularly the interfaces to the dash. Shoebox has all the connector pinouts on his website. Studying them will help identify the differences.
http://shbox.com/1/schematics_wiring.html
To be able to scan with an OBD-II scanner, you need to swap your 12-pin ALDL connector out for the 16-pin OBD-II connector, then make sure you connect the correct wires from the 97 LT1 PCM to the correct pins.
Old Mar 3, 2009 | 02:03 PM
any idea how i would do that or what colors to match up?
Old Mar 3, 2009 | 10:20 PM
You need the wiring diagram for the 97 ALDL connector. My Chiltons has a 96/97 diagram that show that the PCM has 3 wires that connect to the ALDL connector:
Conn #4/pin 7 (does not indicate purpose) - purple
Conn #4/pin 20 (output/field service enable) - white/black
Conn #4/pin 30 (serial data) - tan
You should check that with another source, because Chilton's isn't always reliable (Shoebox has 96/97 connector pinouts on his website).
As far as which pins in the ALDL connector serve which purposes:
Pin 2 = serial data
Pin 4 = ground
Pin 5 = ground
Pin 6 = output/field service enable
Pin 9 = serial data
Pin 16 = Battery voltage
Connector pins are arranged:
1 - 2 - 3 - 4 - 5 - 6 - 7 - 8
9-10-11-12-13-14-15-16
If I was doing a swap like this, I'd make sure I had a set of the factory (Helm) manuals for a 1997. The info I am giving you is off references I have, but there is no substitute for the factory info.
Old Mar 4, 2009 | 02:20 AM
TBSPW's Avatar
how hard would it be to put a 97 cluster in a 96...is it a straight swap or if not can it really be that hard?
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Jun 19, 2015 01:34 PM
blac94Z
Apr 22, 2015 04:53 PM
blac94Z
Feb 10, 2015 11:02 AM
