cutting the steering wheel hub
Old Jul 12, 2008 | 03:46 PM
tom3's Avatar
I am trying to remove the steering wheel:
- two sets of pullers ripped their threads
- hammering the column while pulling doesn't yield anything
- the whole thing's soaked in WD-40 didn't help
- I even froze sprayed the steering column to see if contracting would help
it doesn't move!
I'm so frustrated with the car in the last couple weeks I'm now favoring cutting/hacking things and replacing them than trying to find a way.
So, my question is: can I dremel out the wheel? I was thinking making a hole and then grinding toward the center until it touches the hub. Do you think that would work?
Old Jul 12, 2008 | 04:27 PM
tom3's Avatar
I've just tried the puller one more time: now both sides have no thread anymore and are totally smooth!
I also hammered the center hub like hell while pulling, but nothing
Old Jul 12, 2008 | 06:12 PM
Green96Z's Avatar
You must be doing something wrong, because I've pulled the steering wheel many times with a puller with no problems. Drill out the holes and retap them, then use the puller. Don't try to pry the wheel up, you can damage the column. I know it sounds stupid, but did you take the nut off?
Old Jul 12, 2008 | 06:53 PM
Are you sure you took the nut off? I pulled the wheel with a $6 Grant puller, in about 5 minutes.
Old Jul 13, 2008 | 02:00 AM
tom3's Avatar
yes, I removed the nut, but it feels like the wheel's totally stuck, no play at all.
I hope the night soaking in wd40 will make a difference, but it looks like it's going to take a lot of force to take it out.
I have to either cut the wheel, or drill / tap new holes to try the puller again.
Old Jul 13, 2008 | 08:23 AM
WD-40 is not the best penetrating oil. PB Blaster is a lot better.
Old Jul 13, 2008 | 12:05 PM
mdacton's Avatar
your not doing something right......the bolts are kind of small.....
get a balancer puller and drill/tap the hols to a 3/8 thread.....the bigger bold should help. And the PB blaster......
Old Jul 13, 2008 | 02:16 PM
tom3's Avatar
I think I found part of the issue!
when I look around the hub, the wheel is not sitting straight on, one side is about 1/2 mm more in, so something is not straight.
the only time the wheel was ever off was back in 96/97 when the dealer did a service bulletin (airbag wires).
I can take a pic if it explains the problem more. I'll go get some penetrating oil to see if that helps
Fastbird93
Apr 9, 2016 07:01 PM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
Airplanedoc
Feb 1, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
