How many lbs of r-134?
My a/c stopped blowing cold air so i'm planning to vacuum everything out and recharge it. How many lbs of R-134 should I put back in? I've heard 32oz. Am I correct? I'll be using the R-134 from a container used for refridgerators. Are special oils needed for a car's compressor?
No need to dump/vacuum unless it's already completely empty, right?
http://shbox.com/1/ac_performance_chart.jpg
Just had mine recharged and they put 850 grams of gas back in there and 18ml of oil.They only managed to recover 215 grams of gas and 3 ml of oil so it was definitely in need of doing
Okay, so I looked in the manual. Stock fill is 2 lbs. So since I'll be vacuuming everything out, since it's full of air and probably moisture I'll put back 2lbs of r-134. My new delima is how much oil should I replace. Stock fill is 8oz. but I don't think all 8 oz. will be vacuumed out. Anyone know a rough estimate as far as how much oil should be replaced?
18ml of oil? That's only slightly over half an ounce. Do you know how they came to that amount?
I bought a can of oil from Kragen and it's 8oz oil with 2oz 134.
But I'll be using the vacuum and refilling the 134 from work.
The stuff is made for refridgerators so that's why I have to add the oil seperately.
