cutout switch wiring..
Old Jan 26, 2007 | 02:20 PM
nodnarb481's Avatar
I did some searching and I still have some questions...
Ive got my center console out now and I was wondering.. Is it possible to wire the cutout switch to my transmission perform switch? I was thinking of pulling that harness out (i dont use the button anyways) and hooking it up to the power to that button (if its 12v.. i dont know if it is) I guess the question before I get too confusing is if I wanted to hook it up to that button how would I do it?
Second: I read that there is a random pink and black wire under the carpet somewhere that I can use for power. Anyone have a picture of it? or know if its only on certain cars?
I also found some cable when pulling the console. It was glued to the bottom of my console underneath the AC controls and it goes up into the radio somewhere. I dont think its stock.. Ill take a picture and hopefully someone good with electrics willl know what kind of wire it is..
Finally: Here is the switch I have
Theres six prongs.. what hooks up to each prong?
Thank you for answering to my n00bness
Old Jan 26, 2007 | 02:50 PM
nodnarb481's Avatar
here is the cable i found.. sorry for the ****ty picture...
it just goes up into my radio and I didnt feel like removing more to findout what it was.. hopefully someone can tell what kind of wire it is from the picture
Old Jan 26, 2007 | 03:12 PM
myslowcamaro's Avatar
hard to see in the pic, how many conductor?
Old Jan 26, 2007 | 05:47 PM
xstoyz's Avatar
looks kinda like the cable going to a CD chganger from a Headunit.
Old Jan 26, 2007 | 06:04 PM
nodnarb481's Avatar
thats what i thought it might be.. i believe it has 8 colored wires inside
Old Jan 26, 2007 | 06:08 PM
i didnt tear my dash apart but on my cd player, i have a cable with 8 conductor also. so you guys probably got it. looks like that type of wrapping too
Old Jan 26, 2007 | 06:12 PM
nodnarb481's Avatar
Think one of them is a 12v power supply?
and you guys have any info on my other questions?
Old Jan 26, 2007 | 11:13 PM
nodnarb481's Avatar
im gonna have to send this one on up to the top:
I almost finished modifying my 3.5" QTP to fit on my 3" cutout. After drilling in the holes and alot of chissling it fit nice. Problem was its too thick and the wing nuts barely get on the threads (without the gaskets I have to put on. So Im going grind the bolts off the cutout and just put in some longer ones. In the end this is going to be pretty cool and I hope to feel accomplished.
Any word on my wiring questions?
Old Jan 27, 2007 | 10:31 AM
I guess you could use the brown wire from the performance switch. It is fed by a 15A fuse. The brown wire to the transmission range switch (the switch in your shifter) might be a better choice as it is fed by a 20A fuse.
The "hidden" wires are only on Camaros.
Old Jan 27, 2007 | 05:00 PM
nodnarb481's Avatar
alright so i decided id wire it up to the cig lighter because it was closer to the ashtray and my switch doesnt have any LED or anything on it to drain the battery. I am currently gluing my ash tray back together since it broke when i was drilling it and then ill be able to just throw it in there and its done.
Then I gotta remove my cutout (conveniently not welded in and held on by three bolt flanges) and then grind off the bolts to make way for bigger ones that will be able to hold the QTP on. Hopefully ill be done tonight
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
tdigger9899
Sep 7, 2015 10:56 AM
