Crate Engine with Twin Screw S/C
I wanted to know if the zz4 is a good motor claimed 355hp and 405ftlbs to be swapped into my 89 camaro rs, also i wanted to know if it is better then the LS1 like what is the strengths and weaknesses? Also do u know what kind of gas mileage i could expect to get with a zz4 powered 89 RS camaro...
Re: Crate Engine with Twin Screw S/C
zz4 with a TH350 and 4.56 geats....about 6mpg
zz4 with T56 six speed and 2.73 gears....about 30mpg
depending on your setup...anywhere in between
:blah:more info is needed
i say the LS1 has more power potential. considering a simple cam upgrade and associated tune can have you making 450hp at the crank with stock heads. and still be running 20-25mpg on the highway depending on the trans and rear.
my setup...granted in a 4th gen...is putting about 400hp to the wheels now that it has a good clutch and other goodies since the dyno run...and i get 18/24 city/highway
How about a twin screw ZZ4?
http://64.233.187.104/search?q=cache...e+engine&hl=en
hotrodyou1
Dec 20, 2014 10:05 PM
