Crank seal
Old Jul 18, 2011 | 07:04 AM
brian12's Avatar
Crank seal
Will a leaking crank seal sling oil all over the opti? . I'm about to install a new opti due to the original being ruined by oil contamination. I've already replaced the water pump and opti seals and will be replacing the intake gasket as well in a few days. Seeing as how there was such a huge mess all over the timing cover I can't tell if it was leaking or not. I'd rather not have to pull the hub.(pain in the ***).
Old Aug 1, 2011 | 03:15 PM
marc1130's Avatar
Re: Crank seal
pulling the hub isnt that big of a deal. I used a bolt type puller with grade 8 bolts and replaced mine. I'd hate to spend hours doing a job like that only to find a 2 cent part I did not replace caused an oil leak
HectorM52
Jul 30, 2017 11:46 AM
dylan1303
Aug 12, 2015 02:00 AM
jwade88
Jun 14, 2015 09:38 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
1LEThumper
Jul 14, 2003 12:45 PM
