Cooling fan
Old Jan 6, 2012 | 09:26 AM
sowkins79's Avatar
Cooling fan
I have problem with my cooling fan in 95 camaro z28
The fan start after couple mins after I start engine and the check engine goes on
When I stop the car after few second fan goes off and check engine light goes off too
When I driving fan is on all the time but the temp it's ok
Old Jan 6, 2012 | 10:05 AM
Re: Cooling fan
The fan is programmed to come on when the check engine light does. Scan and find out what is causing the check engine light, fix the cause and the fans won't come on like they are doing now.
Old Apr 22, 2012 | 11:16 PM
sh233252's Avatar
Re: Cooling fan
I have just experienced this same issue, have you been able to find out what the problem was?
Cheers,
Shea.
Old Apr 23, 2012 | 10:36 AM
sh233252's Avatar
Re: Cooling fan
Checked my fuses in the fuse relay box, water pump fuse was blown, replaced and now no troubles.
Old Apr 23, 2012 | 06:28 PM
Re: Cooling fan
I think you may mean the fuse for the AIR pump. The water pump is driven by a gear off the cam sprocket. There is no PCM code or fuse for the water pump.
Old Jun 24, 2014 | 07:36 AM
robertgscott's Avatar
Re: Cooling fan
Going to try replacing the fuse today, as my 95 Z28 has the same issue. thanks for the tip.
Noct
Jul 14, 2015 01:18 AM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
warmeck
Jun 5, 2015 05:19 PM
Biggiebound
Apr 23, 2015 08:50 AM
