Coolant light on with full coolant system
Old Oct 16, 2018 | 09:11 AM
Vincent99's Avatar
Got a 95 lt1 and the low coolant light keeps coming on and off at about 10 to 15 minute intervals weather it's at speed or not what I've checked the coolant and it is not low what sensor could be faulty and where is it?
Old Oct 16, 2018 | 09:30 AM
DrewHMS97SS's Avatar
Re: Coolant light on with full coolant system
It could be the coolant sensor or a short (since you say it is coming on and off). The sensor is attached to the radiator, engine side, about 3-4 inches below the radiator cap.
Old Oct 16, 2018 | 12:16 PM
Where are you checking the coolant level? You can’t rely on the dipstick in the reservoir. You have to check the level in the radiator when it’s not real hot (to avoid boil over or getting scalded). Should be full, right up to the fill neck at all times. Any air in the LT1 cooling system can cause overheating and eventually, a blown head gasket.
A faulty coolant level sensor is a very common problem. Can get full of crud, or the coolant penetrates the seal and corrodes the printed circuit board. But be sure you are checking the level in the correct location.
TaskForce141
Jun 18, 2013 06:42 AM
Z28LT1_Just_Nasty
Jan 22, 2006 10:25 PM
CrippleFightin
Sep 21, 2003 11:45 AM
TobyZ28
Jun 30, 2003 09:59 AM
