Coolant level sensor
I have the same problem on my 97 Z28.
Where can you get it for 15-20 bucks?
I don't see it on autozones webpage or advanced discount auto parts.
I know the dealer has it for like 45 cost and over 50 list.
Let me know that light is driving me nuts.
Thanks,
Chris.
Thanks,
Chris.
Re: Coolant level sensor
Yea I heard the same thing.
I sand blasted mine and did not work.
So I have to get a new one.
when I put it back on I guess I did not get that wire back on right.
Three days later it blew off and I over heated the engine.
Thank God I did not blow it up.
Chris.
Chris.
Chris.
Chris.
You can clean it off, but it will die again soon, for $20 you might as well replace it
This happened on both of my LT1's. I just unplugged the sensor and taped it off to the side and out of the way. The light will stay off. If you check your fluids regularly (like we all should) it's not an issue. Hope this helps.
Originally Posted by Blue89Bird
why would you sand blast an electronic device? unless you mean by accident
Well the sensor part of it is what looks like brass.
So I sand blasted it.
You said to "Call up Dal or gm parts direct"
Ok gm parts direct I got but who is Dal?
Thanks,
Chris.
Thanks,
Chris.
Thanks,
Chris.
lockitup@bright.net
VanDevere Buick/Pontiac/Olds, Akron, OH
http://vandevere.com
