Console
Old Apr 23, 2016 | 08:21 AM
daydreamer350's Avatar
Console
So I have a 97 camaro z28 and the console only goes back to D2 and I bought a console that has the D1. Do I have to change the cable that goes to the transmission as well
Old Apr 23, 2016 | 10:26 AM
Re: Console
No.
The only difference between the D2 and the D1 console is there is a plastic blocking tab on the D2 plate to keep the shifter from moving to D1. Some people remove the plastic tab from the D2 console so they can access D1.
Old Apr 23, 2016 | 12:19 PM
Re: Console
Originally Posted by Injuneer
No.
. Ok thanks a lot I appreciate it
Old Apr 23, 2016 | 12:21 PM
Re: Console
[QUOTE=daydreamer350;6986015]. Ok thanks a lot I appreciate it. I just ordered one and going to install it when it gets here. Don't understand what gm was thinking when they made this and the second gear start. Stupid to me.
Old Apr 23, 2016 | 01:21 PM
Re: Console
They had to do it to meet Federal noise regulations.
From the 4th Gen FAQ:
Q: Why is there no selectable 1st gear for my automatic transmission?
A: On cars with automatic transmissions and the 2.73 rear (GU2) 1st gear can't be selected because in order to pass the Federal noise pollution tests, GM had to lock out selectable 1st gear. It has to do with downshifting into the lowest selectable gear at some speed as the car goes through the sound traps.
With the 3.23 rear end, the required speed is high enough that the transmission won't allow a manual downshift all the way to 1st gear. But with the 2.73 gears, the car will downshift all the way to 1st when manually selected thereby increasing engine and exhaust noise. So GM had to prevent 1st gear from being selected on the 2.73 cars in order to meet the guidelines.
However, making 1st gear selectable on these cars is relatively easy. Lift off shifter cover, locate plastic (nylon) stop at the right side of the notched selector ramp, use a hacksaw or X-acto blade to remove the offending (square) stop. Then you will have first gear.
Same as the "Skip-Shift" feature that prevents the 6-speed manual trans from shifting from 1st to 2nd at low speeds.... the shifter is defected to 4th gear. They had to do that to meet EPA fuel consumption requirements, and avoid being classified as a "gas-guzzler".
alex5366
Jun 14, 2015 10:31 PM
Hobbyguy
May 26, 2015 02:15 PM
LimitedEd1LE
May 18, 2015 01:24 PM
jp2002ls1
Sep 4, 2002 03:27 PM
redzed
Aug 28, 2002 11:30 AM
