Compression Check
Old Feb 24, 2006 | 09:51 AM
Dfetter84's Avatar
Compression Check
Here are the results of my compression check
1-202psi
3-202psi
5-202psi
7-202psi
2-200psi
4-202psi
6-202psi
8-202psi
I am going to restest cylinder 2
Does this mean I have my valves adjusted properly????????
Old Feb 24, 2006 | 09:13 PM
OBE1 95Z28's Avatar
Re: Compression Check
No need to retest #2, that's noise level difference. As far as proper adjustment of the valves, it shows that none of your valves are adjusted overly tight to cause a valve to be partically open, but that doesn't mean there adjusted properly. They could be too loose.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
