Compression Check
Here are the results of my compression check
1-202psi 3-202psi 5-202psi 7-202psi 2-200psi 4-202psi 6-202psi 8-202psi I am going to restest cylinder 2 Does this mean I have my valves adjusted properly???????? |
Re: Compression Check
No need to retest #2, that's noise level difference. As far as proper adjustment of the valves, it shows that none of your valves are adjusted overly tight to cause a valve to be partically open, but that doesn't mean there adjusted properly. They could be too loose.
