Wiring/Starter Issue
Old Feb 22, 2006 | 07:59 PM
30thCamaroZ's Avatar
Ok so let me lay down my whole dilemma. My car started blowing fuses. I figured dead short. I found one dead short and fixed it. I go to hook the battery back up and the starter turns over. I go ahead and put in a new starter thinking maybe this one is bad. Same thing. I then find 3 burnt wires in the harness for the 02/knock sensor/starter etc. I pull it all apart and cut those wires and put in a piece of wire reattching each of them I hook up the purple wire to the starter to make sure and it's doing the same thing??? Is it possible it messed up that starter by having such a bad short like that? I didn't change around one of the wires on the starter so I don't think I have a constant 12v source anywhere. I'm so out of ideas right now
Old Feb 24, 2006 | 12:18 AM
kingslam's Avatar
Re: Wiring/Starter Issue
yes you have a possible stuck relay. Your PASSKEY II Module sends the s terminal power on the starter (pur[le wire) through a relay. Could also be a bad starter switch too, I would test the relay 1st.
Old Feb 24, 2006 | 07:32 AM
You should be checking the purple wire for a constant 12v. It should only have power when the key is in the START position. Make sure you are putting the wires on the starter on the correct terminals.
Old Feb 24, 2006 | 09:18 PM
I fixed it. Turned out the ground wire in the same harness as the purple wire was not grounded. Somehow giving the purple wire a constant 12 volts is all I can guess. Thanks for the help though guys
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
