this common with 10 bolts ???
Old Apr 19, 2004 | 08:05 PM
Hyperspeed97z28's Avatar
Question this common with 10 bolts ???
To get a little bit of metal in with the gear oil when doing fluid changes???
Old Apr 20, 2004 | 05:08 AM
TTT....
25 views and no answers.....
Old Apr 20, 2004 | 09:28 AM
coogsLS1's Avatar
how much do you have in there? From what I have heard it is fairly common on 10 bolts.
Old Apr 20, 2004 | 09:14 PM
it was literally 4-5-6 little pieces maybe the size of bb's not even...
Old Apr 20, 2004 | 09:35 PM
Capn Pete's Avatar
Was it like very fine metal shavings (like what you find on the engine oil pan drain plug), or actual "chunks" of metal the size of BB's?? Fine metal shavings are normal, and may even appear almost like a solid piece if it's collected together for awhile, but if you got actual metal chunks, you may want to take a closer inspection and make sure there aren't any broken or chipped gear teeth inside.
Old Apr 21, 2004 | 05:10 AM
4-5 actual bb sized pieces...
Old Apr 21, 2004 | 06:32 AM
z28chrizz's Avatar
only superfine shavings in mine... but I do the axle at least yearly, and run semi syn gear oil...
bb size... not so good, really gotta find out where that metal came from...
Old Apr 21, 2004 | 12:47 PM
rpm4lalo's Avatar
the size of BB's.
Not good.
maybe a bearing is falling apart?
Remove cover and check it out, or have it checked.
Rearend hasn't been howling or grinding?
Old Apr 22, 2004 | 09:08 PM
no grinding or howling...
havent had the chance to mess with it yet, been working long *** hrs this week
Old Apr 22, 2004 | 10:01 PM
ishz28's Avatar
I had two big *** pieces of ring teeth fall out . Is that bad Maybe that's what the thump-thump noise is when I'm slowing down.
Old Apr 23, 2004 | 02:09 AM
Est96Z28's Avatar
Probably from bearing(s), but I wouldn't do anything before they start making noise.
Old Apr 23, 2004 | 08:47 AM
so then I'll be good to put fluid back in and drive it til she blows ??
the rear end that is.. hehe
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
mattstrike
Mar 11, 2015 07:33 PM
