Code P0101
Old Aug 14, 2011 | 01:32 AM
aknight_sa's Avatar
Code P0101
i have just replaced the MAF on my 97 Camaro with LT1 engine, the issue is i still get the error code P0101 on my OBD2 scanner.
what could cause this error to hold on? from the scanner i see that the MAf is working, and when i disconnect it the engine runs rough! so it seems to be that it should be working properly?
what could cause the error to keep showing up?
Old Aug 14, 2011 | 08:18 AM
Re: Code P0101
Did you clear the code after replacing the MAF?
What does the MAF read at idle?
The code is based on a rationality check, comparing the mass air flow reported by the MAF sensor to the mass air flow calculated using the speed-density method.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
