code 15....how to fix
Old Jun 21, 2007 | 07:25 PM
reamo04's Avatar
i got a code today after starting the car for the first time in a week or so.
15 Engine Coolant Temperature (ECT) Sensor Circuit (signal voltage high, low temperature indicated)
we just rerouted my plug wires, and changed out my accessory bracket, so what could have caused this code to come up, how do i fix it?
Old Jun 21, 2007 | 07:31 PM
Maybe you left the sensor unplugged.
http://shbox.com/1/4th_gen_tech2.html#ect
Old Jun 21, 2007 | 07:38 PM
reamo04's Avatar
previously, i kept having the "low coolant" light showup, so i unplugged the sensor. Would that cause it? Otherwise, what other sensor could it be? The water pump one? We didnt mess with that. sorry, i read through that but it kind of confused me right now
is it possible that the coolant is just low? My car is still too warm to go check
Old Jun 21, 2007 | 08:47 PM
reamo04's Avatar
whats the best way to get to the water pump sensor without tearing everything out? I think i could have knocked it loose or something since we changed the accessory bracket
Old Jun 21, 2007 | 10:35 PM
The low coolant sensor would have nothing to do with it. The temp sensor on the water pump is easily reached from underneath. Make sure you did not smash the wiring with the accy bracket install.
Old Jun 22, 2007 | 12:37 PM
reamo04's Avatar
well, i believe i do have a problem with the wiring somewhere making it not read right, which is also making my car hard to start. Just gotta try to hunt it down now i guess. If its the sensor itself, what does it take to replace it?
Old Jun 22, 2007 | 12:40 PM
JAB's Avatar
JAB
You just unscrew the old one and screw the new one on. Do it quickly because you will lose coolant out the hole. Make sure before replacing it that you didn't bend the pins in the connector. I did this once and it wasn't getting a good connection.
http://shbox.com/1/temp_sensor1.jpg
Old Jun 22, 2007 | 12:44 PM
reamo04's Avatar
i found the sensor, and plugged it back in and it seemed to fit good. No pinched wires or anything, have to try starting it again i guess
Old Jun 22, 2007 | 01:06 PM
JAB's Avatar
JAB
My connector still felt like it fit fine also but the connectors on the pigtail were bent outward inside the connector and weren't making contact with the pins.
Old Jun 22, 2007 | 01:13 PM
reamo04's Avatar
what did u do to fix it? replace the pigtail?
Old Jun 22, 2007 | 01:22 PM
JAB's Avatar
JAB
I got a small screwdriver and bent them back in.
Old Jun 22, 2007 | 01:47 PM
reamo04's Avatar
tried that, no luck. What would my next step? Test the sensor itself or start tracing wires?
Old Jun 22, 2007 | 01:49 PM
JAB's Avatar
JAB
I would test the sensor via shoebox's guide he posted.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
MislMan
Jul 19, 2002 11:41 AM
