Clock staying on when car is off
I’m having a problem with my 94 Z28, the clock on my radio remains on, drains my battery, checked the RCL button, not stuck.
I found tonight that if I pull the courtesy fuse the clock will go off. Could this be a BCM, RAP issue or just a bad factory radio?
Re: Clock staying on when car is off
No BCM in a 94. Was added in 1996.
Which radio…. Bose or standard? And the radio is “off” when the key is “off”? Only the clock stays illuminated?
I believe with the Bose system, the clock and memory are directly powered by non-switched power from the courtesy fuse. Looking at the schematic for the Bose, would not involve the RAP module. The RAP feeds power from Radio fuse 17.
http://shbox.com/1/bose_wiring.jpg
http://shbox.com/1/rap_schematic.jpg
I can give you a link to the 1994 factory service manual.
So….. without “notification” you just happened to come back 33-minutes after he posted his response, you (hopefully) read his simple question….. but didn’t bother to post a simple 1-word response. You must be a verrrry busy person. Good luck.
