clicking sound
Old May 6, 2012 | 12:23 PM
94Z28LS1toLT1's Avatar
clicking sound
When i turn the ac on do the fans change speed throughout the the driving, i keep hearing the same clickin sound when the ac clutch is engaged,when im sittin at a lite or stop sign
Old May 6, 2012 | 05:18 PM
mab6680's Avatar
Re: clicking sound
the fans should not be making a clicking noise it sounds more like the ac compresser is clicking when it cycles
Old May 6, 2012 | 09:47 PM
Re: clicking sound
is the ac compresser supposed to to do that my air is blowing cold n no sign of leakes and i checked the line 2 lines n according to the haynes manual the top one is cool m bottom one is warm so system is properly charged
Old May 7, 2012 | 08:48 AM
bobdec's Avatar
Re: clicking sound
On a properly charged system the a/c clutch will cycle on and off. There is a temp sensor in the evaporator coil that turns off the a/c clutch at 33* F and back on at 36* F this is to prevent it from freezing up. HOWEVER in a system with a LOW charge the a/c clutch will also cycle on/off as the coolant pressure drops below a predetermined level. In that case the a/c will not be blowing cool enough air which is very noticeable. If yours is cold it looks like the first case is what you are seeing.
Old May 7, 2012 | 12:59 PM
mab6680's Avatar
Re: clicking sound
yes my compresser new and it clicks when it cycles and my air blows out at 55 deg it perfectly normal
Old May 7, 2012 | 02:47 PM
Re: clicking sound
Thank u guys cool
May 21, 2015 01:04 PM
REDNECKISBOSS
May 20, 2015 10:03 PM
May 15, 2015 10:43 AM
cmsmith
Apr 30, 2015 05:18 AM
HuJass
Jun 27, 2002 11:04 PM
