clearance issues
Re: clearance issues
Don't think there is much you can do on an old exhaust. You could try loosening all the clamps and jacking up the part that scrapes. But it will probably rebound back to where it was.
I did the same thing. I think we're sol bro... I'm having the same issues. I've heard that true duals tuck up pretty well. I've also got the SLP lt's... :rolleyes. I scrape my cats on everything.
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i have the opposite problem...
when i press the gas with any amount of force my ypipe vibrates up against the bottom of the car because of extremely little clearance...
without welding or bending anyone know of a solution? ideally i would like to find some material (basically a padding) that can withstand the heat of being wrapped around exhaust tubing
any input appreceiated
LS1 Bump Stop Hanger by Thunder Racing
I used the bolts from the Trans-mount cross brace to bolt it to the car, but you can also weld it (welding would be ideal). It works GREAT!
best of luck to ya!
JasonD
Aug 27, 2002 10:57 AM
