Cleaning Mass Air Flow Sensor...?
I saw a spray at Autozone today thats suppose to be used for cleaning the MAF. Anyone ever use it and see results? Does the MAF really get that dirty as to cause a decrease in performance?
Re: Cleaning Mass Air Flow Sensor...?
did QD make it? someone recently said it smells a lot like the QD Electric cleaner....prob not much difference - both will get the job done
Sprays, IMO, are the safest way to clean MAFs
Originally Posted by Dave '97 Z28 M6
MAFs often get contaminated by oil from an over-oiled K&N filter. As has been suggested, a spray (aerosol) electrical contact cleaner does the job.
I've cleaned mine everytime I clean the throttle body.
Seems to make a bit of difference everytime.
I use electronic contact cleaner on the MAF and fuel injection cleaner (similar to carb cleaner) on the throttle body.
Originally Posted by V8 Slayer
What do you do? Just give it a few quick sprays and thats it? No wiping or anything?
The electronics cleaner is a residue free and fast drying spray.
I take the MAF off of the car and put it gently down on the garage ground then spray away.
Originally Posted by StephenDeli22
Do you spray pretty liberally?
Ya, kind of - I give it a direct shot of the cleaner for about a total of 10 seconds or so.
You spray the wires inside the MAF correct?
What should you use to clean the MAF screen, mine is filthy?
I think for the screen, maybe SeaFoam's Deep Creep - just dont get it on the sensors.
