Cleaning Mass Air Flow Sensor...?
Old May 26, 2006 | 09:53 PM
V8 Slayer's Avatar
I saw a spray at Autozone today thats suppose to be used for cleaning the MAF. Anyone ever use it and see results? Does the MAF really get that dirty as to cause a decrease in performance?
Old May 26, 2006 | 11:31 PM
fredmr39's Avatar
Re: Cleaning Mass Air Flow Sensor...?
did QD make it? someone recently said it smells a lot like the QD Electric cleaner....prob not much difference - both will get the job done
Sprays, IMO, are the safest way to clean MAFs
Old May 27, 2006 | 01:54 AM
Dave '97 Z28 M6's Avatar
MAFs often get contaminated by oil from an over-oiled K&N filter. As has been suggested, a spray (aerosol) electrical contact cleaner does the job.
Old May 27, 2006 | 03:11 AM
fredmr39's Avatar
or just in general from pollutants in the air that get past air filters - everyone should have to clean it at some point
Old May 27, 2006 | 09:53 PM
Pandamonkey's Avatar
I've cleaned mine everytime I clean the throttle body.
Seems to make a bit of difference everytime.
I use electronic contact cleaner on the MAF and fuel injection cleaner (similar to carb cleaner) on the throttle body.
Old May 27, 2006 | 11:36 PM
V8 Slayer's Avatar
What do you do? Just give it a few quick sprays and thats it? No wiping or anything?
Old May 28, 2006 | 12:53 AM
V8 Slayer's Avatar
How do you wipe it out and not touch what you have sprayed..lol ?
Old May 28, 2006 | 01:12 AM
No wiping - DEFINETLY no wiping.
The electronics cleaner is a residue free and fast drying spray.
I take the MAF off of the car and put it gently down on the garage ground then spray away.
Old May 28, 2006 | 08:54 AM
StephenDeli22's Avatar
Do you spray pretty liberally?
Old May 28, 2006 | 10:17 AM
Ya, kind of - I give it a direct shot of the cleaner for about a total of 10 seconds or so.
Old May 28, 2006 | 10:22 AM
V8 Slayer's Avatar
You spray the wires inside the MAF correct?
Old May 28, 2006 | 11:10 AM
What should you use to clean the MAF screen, mine is filthy?
Old May 28, 2006 | 12:55 PM
Sure do.
A direct spray right on them.
Old May 28, 2006 | 05:50 PM
fredmr39's Avatar
try spraying stuff as well - but, spray in the direction away from sensors (possible?) idk... wipe down the other side, just to be safe and not get any debris on the sensors that might cause harm/poor function/you to clean it again.
I think for the screen, maybe SeaFoam's Deep Creep - just dont get it on the sensors.
Old May 28, 2006 | 10:57 PM
I was thinking about dipping it in brake cleaner and not getting it on the actual sensor...
