cd player question
Old Jan 3, 2008 | 09:18 PM
justinsbad95z's Avatar
cd player question
I have a 95 camaro z 28 that has a bose cassett player will the bose cd player work in my car if it is for the same year make and model. Will I have to do anything to make it work?
Old Jan 3, 2008 | 09:48 PM
TraceZ's Avatar
It's direct plug and play.
In fact, you can even get a non-Bose CD player and just swap the Bose pre-amp section onto it. It's just a few screws and the unit comes apart into modules. The Bose module from your cassette player will fit on a standard CD player.
In this picture you can see both modules. The Bose (foreground), and the standard. Note that the Bose has a smaller heatsink because it is preamp only.
Here is a picture of the CD module.
The CD module connected to the face
Just the face
Bose on the left, standard on the right. Note the heatsink difference.
how the preamp / amp section can seperate off.
Old Jan 3, 2008 | 10:34 PM
Thanks a lot man that is so helpful i really do appreciate it.
Old Jan 4, 2008 | 12:14 AM
TraceZ's Avatar
No problem! Post your results.
Old Jan 6, 2008 | 04:56 PM
zaxon's Avatar
I don't mean to hijack the thread, but I need to know if it would be at all possible to keep my bose system in my 95z and swap in an alpine touch-screen. OR should I stop screwing around and put in new speakers all around and a sub in the rear?
Old Jan 6, 2008 | 05:04 PM
TraceZ's Avatar
You could get it to work with an adaptor harness.
If it were me, I'd just replace everything at that point.
I prefer to use factory head units to keep the dash looking stock and lessen the chances of a break in.
Old Jan 6, 2008 | 10:12 PM
zaxon's Avatar
I would keep the stocker, but the cd player no longer works and I would rather have a fully functional one that I can plug my ipod directly into.
I'm going to go all after-market, I have some pioneer speakers sitting around here somewhere, I'll just have to make use of them
Old Jan 7, 2008 | 12:16 PM
yournamehere's Avatar
Crutchfield helped me, I bet they can help you too. TraceZ you really seem to be up on your electronics. For about 10 years I worked at a Delco subcontractor repair center, and when questions about Bose head units came up the standard answer was to replace/repair the Bose head unit. I have'nt been able to leave the stereo alone in any vehicle I've owned, starting with my first car. Crutchfield sells an adapter harness that allows aftermarket head units to work with the Bose amps/speakers. I prefer Pioneer head units and was very happy with the results. Crutchfield also has easy to follow directions for taking the car apart and putting it back together.
TraceZ: what do you think about the sub enclosures that fit in the drivers side of the lower hatch area, opposite of the spare tire ? Think a sub could be put in there probably with an aftermarket amp for power ? Thanks
Old Jan 8, 2008 | 02:16 AM
zaxon's Avatar
Does anyone think this Crutchfield harness will work, pending I do keep the bose speakers?
http://www.crutchfield.com/App/Produ...C4GM02&tp=3486
Old Jan 8, 2008 | 07:32 AM
TraceZ's Avatar
The factory Bose system uses line level outputs. These line level outputs use the connector pins that are otherwise used for speakers on non-Bose systems.
I'm sure your new head unit will have line level outputs, so there is no need to use a harness like the one you linked to that converts speaker level to line level.
What you can do, is make your own. I'd recommend getting the basic adaptor for the camaro, the one they sell at Wal Mart and soldering 4 RCA jacks onto it. Then plug the harness into the car and the RCA Jacks into the radio. A couple other wires like Bat+ Ign+ Gnd and Ilum and you are done.
It won't be too hard to do.
CaRParts102
Dec 6, 2014 08:45 AM
SLIMJIM
Jan 7, 2003 11:06 AM
Teal94V-6
Aug 31, 2002 09:21 PM
SVT3852
Aug 16, 2002 03:35 PM
Evilfrog
Aug 7, 2002 11:36 PM
