Car won’t crank
Old May 26, 2020 | 01:01 PM
Spencerz28's Avatar
Car won’t crank
just got a car with no motor i installed one the only diagram I found for the starter is one wire goes to the small wire in the hot wire goes to the big terminal but it will not crank over any help please
it’s a 1995 z28 with a lt1
Old May 26, 2020 | 02:40 PM
Re: Car won’t crank
You are indicating the starter will not engage and crank the engine when you turn the key to "START". The starter circuit includes the Theft Deterrent Relay (TDR) which prevents the starter from engaging unless the resistor in the ignition key pellet matches the resistance programmed into the Theft Deterrent Module (TDM). Is the "SECURITY" light on?
Or, are you trying to activate the starter by applying 12 volts to the purple wire that runs to the starter?
1995 Starter diagram from factory service manual, courtesy of Shoebox:
http://shbox.com/1/starter_charging_95.jpg
Old May 26, 2020 | 05:25 PM
Spencerz28's Avatar
Re: Car won’t crank
Yes the security light is on and no I was trying to fidgure out if I have the starter wired correctly I have the purple going to the small post and the 12 v from the battery going to the big one but there is also a black wire down there that I’m not sure if it goes on the starter or not
Old May 26, 2020 | 06:36 PM
Re: Car won’t crank
The harness bundle for the purple wire to the starter also includes the 4-wires/connector for the passenger side O2 sensor, a single dark blue wire/connector for the knock sensor, and a black wire with an eyelet that gets attached to the block and grounds the PCM. Shoebox's excellent labeled photo of a 1995 engine wiring harness:
1995 Z28 A4 Engine Harness
http://shbox.com/1/harness3.jpg
If the “SECURITY” light is on while trying to start the engine, there's a problem related to the PAS-Key (VATS) system. Another great Shoebox guide:
4th Gen LT1 F-Body Tech-PassKey/VATS
A problem with VATS can prevent the starter from receiving power.
ENRKyle20
Jun 8, 2008 08:47 PM
ENRKyle20
Jun 6, 2008 03:37 PM
Josh'95Z28conv
Sep 12, 2006 10:37 PM
cwaldt
Mar 30, 2006 03:33 PM
limige
Sep 17, 2005 08:07 AM
